Suspension Question -Need advise
Old Jan 11, 2012 | 10:38 PM
dodgeramguy85's Avatar
dodgeramguy85
You said when coming to a stop you could feel a lot of slop. Does either side of your tires look like this?
I had a bad pull after my accident. Steering wheel was cocked and all. Weird thing was when I put on my brakes at about 10mph or less the steering wheel would fix itself and it wouldnt pull anymore. My upper control arm was loose and letting it go back and forth in its alignment slots so it had 2 in of play. Weird thing was when jacked up with the tire off I didnt have any play at all. I finally figured out to throw a jack under my lower ball joint and jack it up till it was level and sure enough it moved when it got high enough.
Old Jan 11, 2012 | 10:56 PM
ksJoe's Avatar
ksJoe
Originally Posted by jondakotaguy
Plus I don't like the constant back and forth action.. I know part of it is the stearing box; these old styles always had an issue like that.. walking back and forth as driving..
By "walk back and forth" do you mean sloppy and wandering? That sounds like suspension issues.
But, if you have wide, fully inflated tires, and you're driving on asphalt with ruts in it, it may be tramlining. My IS350 has wide high performance tires and it does that. It takes some getting used to, but there's nothing wrong with it. If this sounds like it could be whats going on, find some smoother pavement and see if does better.
As for the ball joints and tie rods, jack up the wheels and shake and twist on the wheels.
Old Jan 13, 2012 | 03:22 PM
jondakotaguy's Avatar
jondakotaguy
I would say sorta have to stear back and forth left right to keep going strait.. as the truck pulls to the right.. but slowing down (with or with out breaks)..
My father knows a hell of a suspinsion alignment guy said he would go through my truck compleatly for 10 bucks. I'm going to let him take a look.
Old Jan 13, 2012 | 04:17 PM
DGjohn3's Avatar
DGjohn3
If all the ideas that everyone has posted, try installing a sway bar... Reduces swaying and body roll. Look into it, see if that could be a solution for you.
Old Jan 13, 2012 | 08:00 PM
ahsnowlover's Avatar
ahsnowlover
I would check your torsion bars make sure that they are tightened the same, when I tightened mine I didn't get them the same and I noticed that one side tended to lean a bit more as soon as I got them the same it fixed it
Old Jan 14, 2012 | 12:58 PM
jondakotaguy
Exactly what I was thinking.. the Friend of my dad is going to go through everything for 10 bucks and make sure they are correct.. and tell me every parts that needs to be replaced right away and what can wait.. basically what ever it will take to get it where it drives strait and stops pulling..
Guy is supposed to know his stuff.. so I don't to just start dropping money in this thing.. so it's def. worth 10 bucks to get a pro's opinion and go from there. I'll let you guys know how it turns out and thanks for all the great advise!
