Instant Stain remover including rust!
Just for you guys if you can find it somewhere near you.. the stuff is called BlueMagic and its in a silver (mostly) and blue can..
This stuff is made right here locally in Texas; Conroe Texas to be exact.. this stuff works.. Spray it on the spot and watch it magically turn back to factory color.. but you have to get up the solvent.. best results use a good suction, shop vac didnt seem to cut it.. you can pad it up with a towel but best results i found was
Something like this (Just the suction nozzle)
I used this on my carpet for rust colors.. I have large spots i need to do still as i only did the sides.. but the stuff works.. no scrubbing.. watch it turn colors before your eyes.. just make sure you get it sopped up or suck it up somehow else the color will reappear as the solution from the can and what its taking out the carpet will reset in..
