plug
Old Jan 18, 2012 | 09:03 PM
BLSHOG10's Avatar
BLSHOG10
Default plug
hey guys hope everyone is doing well... i had a quick question does the radiator drain plug on a 2000 3.9 remove completely or does it only loosen when you turn it ....i want to make sure before i force it out and break it
Old Jan 18, 2012 | 09:40 PM
1986JEEP's Avatar
1986JEEP
No it does not come out all the way.
Old Jan 18, 2012 | 10:16 PM
98DAKAZ's Avatar
98DAKAZ
Lightbulb I suggest not using the drain plug
I suggest not using the drain plug they tend to snap off then you have a problem besides they drain so slowly.
Best is just pull the bottom rad hose it all comes out in a flash just beware its HOT and could splash you but if you want to flush the system there is no better and faster way to do it.
Best is just getting the system warm not hot before you do it.
Old Jan 18, 2012 | 11:18 PM
BLSHOG10's Avatar
BLSHOG10
thanks for the quick replys ..... all you guys are always helpful
