Headlight/dash light/interior lights/fog light problem
Old Feb 1, 2012 | 10:45 AM
Old Man Ace's Avatar
Old Man Ace
Default Headlight/dash light/interior lights/fog light problem
I have a 2001 4X4 Club Cab. The truck was not being used but both headlights came on very dimly by themselves and stayed on. I also discovered that the key fob would not unlock the doors and the interior lights, dash lights, and fog lights did not work either. The headlight switch seemed useless as I could not turn the headlights fully on or totally off and no other function of the light switch worked. Also, the headlight high beam switch did not work. I had to disconnect the battery to turn off the headlights. Does anyone have any suggestions as to what the problem is and how to diagnose it? Thanks.
Old Feb 1, 2012 | 11:44 AM
McNasy's Avatar
McNasy
im sure others will chime in as well, but im gunna say the ctm took a crap on you. do the power locks and windows work? cruise work?
Old Feb 1, 2012 | 12:01 PM
dodgeramguy85's Avatar
dodgeramguy85
Its your ctm. It controls all that crap. Its behind the drivers side kick panel below the parking brake.
Old Feb 1, 2012 | 01:00 PM
Old Man Ace
The lights came on while I was at work (I drove the Jeep yesterday) so I didn't see the problem until I got home after 11:30 last night. She's on the battery charger now until I go to work. I'll recheck everything tomorrow and let you know more. Thanks for the help.
Old Feb 3, 2012 | 10:18 AM
Old Man Ace
I hooked the battery up after charging it and everything was back to normal. All of the symptoms that I described in my first post were gone. I guess it's just a matter of time until the problem returns.
