Can I Fit 35's?
Old Aug 8, 2005 | 01:35 AM
MuddinDakota's Avatar
MuddinDakota
Default Can I Fit 35's?
Does anyone know if 35x12.50R15 would fit on a 99 dak with a 5.5" lift kit? I'm trying to see wheter i need to spend an extra $1k on fenders and bedside that flare 4.5" and raise 3" inorder to fit 35's with the lift i wanna get for my dak.
Old Aug 14, 2005 | 11:13 PM
Crusader121's Avatar
Crusader121
Default RE: Can I Fit 35's?
I have a 01 Dakota with a 3" body lift. I was able to fit 285 75 R16 wich is about 33' by 10.5 and they rub on the frame alittle and I had to cut some of the splash guards out to make front and back clearence. You are going to defentley have to go with off set rims. I really think you are going to have a hard time doing 35's.
Old Aug 16, 2005 | 12:22 AM
Daksport1pa's Avatar
Daksport1pa
You would have to do a 3 in body lift. A 3 in suspension lift and you would still have to trim on the front bumper a little bit. Not sure if it will rub on the frame or not when at full turn.
