Transmissions issue
Old Mar 1, 2012 | 09:09 PM
Chuelz430's Avatar
Chuelz430
Default Transmissions issue
new to this site , looking for possible help
I just picked up a 02 dakota 3.9 4x4 42re
Transmission seems to have a mind of its own
If i creap away from a traffic light its all gd , goes through all the gears
Sometimes takes a high rpm to shift and i have to get off gas for it to upshift . If i give it a little gas from a light the truck will shake violantly , seams like the trans makes a horrible rubbing noise . If i let it get into 2nd easy i can then give it gas and itll pull then bang into gear .
Changed the trans fluid as soon as bought it , lets say its was as black as motor oil and thicker than a shake in the bottom of the pan .
What could it be , trans shot? Slipping hard idk Control module , adjustments . Any help will be great
Old Mar 3, 2012 | 12:21 PM
Dodgeboy77's Avatar
Dodgeboy77
if the fluid was black that is not good but you could try some transmission additive before you take it down.
Old Mar 4, 2012 | 01:50 PM
jondakotaguy's Avatar
jondakotaguy
Yeah If it was black they probably never serviced the thing and I would not have bought it.
