Randomly wont start! No click or anything. Then fires right up??
Old Mar 1, 2012 | 11:04 PM
zeeth2800's Avatar
zeeth2800
Default Randomly wont start! No click or anything. Then fires right up??
I have had this happen on two occasions now.
My truck will randomly not start. No click or turn over or anything. Get lights on the dash but nothing when i turn the key.
Then all of a sudden on maybe the 8th try or so it fires right up without a issue?
Opinions on what this could be?
Old Mar 2, 2012 | 11:28 AM
crateampsrock's Avatar
crateampsrock
you see the lights draw when you turn the key to start? if so it could be the starter hanging up...
Old Mar 2, 2012 | 12:32 PM
bbeebee's Avatar
bbeebee
Sounds like an open somewhere in starter circuit.
Old Mar 2, 2012 | 04:51 PM
gnelson49's Avatar
gnelson49
Have you checked your battery terminal connections??? This is a classic symptom of corrosion between the cable loop and the terminal or corrosion in the cable itself just above the terminal. Clean that up with some baking soda and/or consider replacing the terminals on the cables. Also check the electrical connection between the battery and starter, it is a large cable and make sure it is tightened down well to the starter.
If all of that is good get a load test on the battery and check your starter relay.
Old Mar 2, 2012 | 05:10 PM
thunder98110's Avatar
thunder98110
check fuel pressure
Old Mar 2, 2012 | 08:44 PM
00daksport25's Avatar
00daksport25
Sounds like a starter issue. Start with your battery then check your starter. Also, do you hear the fuel pump when you turn the key?
Old Mar 2, 2012 | 09:18 PM
ahsnowlover's Avatar
ahsnowlover
I had that problem with my truck and if I got out and jiggled the battery and connections then the truck would fire right up. A few months later my batter kicked the bucket without any warning. Since the new batter I haven't had any issues.
Old Mar 3, 2012 | 01:49 PM
PonchoRob's Avatar
PonchoRob
Had the same exact thing happen to my truck . The very first time it done it a few years ago , i had driven to the cemetery with some family members to plant flowers and tend to my sisters grave site , and when we were ready to leave i hit the key and nothing happened - no start , no lights , no radio , no nothing , talk about spooky stuff !! Of course everyone thought i was messing with them untill they tried starting the truck , my youngest sister was calling for help when i tried one more time starting it , and it fired up like nothing was wrong ! Since then it got progressively worse until i was afraid to drive it anywhere i didnt want to be stranded at . I had replaced just about everything related to starting the truck -- ign switch , batt , suspect cables & grounds , sensor in the trans , everything EXCEPT FOR THE STARTER , because it would actually start the truck ( and a new one too expensive ) i figured it for being good , but i still had the problem . When the only part left to replace with new was the starter -- i bought one ---- and a new starter fixed the problem , hasn't done it since !!! Replace your starter with a new one = problem solved !!
Old Mar 5, 2012 | 02:34 AM
moparman_2004's Avatar
moparman_2004
Mine did it the otherday the contact disc inside it will start to pit and whatnot and it just makes a single click and hold the key a sec and try again and the 2-3 rd time it will rotate enough to find a good spot on it to allow power threw and start the truck I did it once and never had another problem with it
Old Mar 9, 2012 | 01:03 PM
DakotaBlue142's Avatar
DakotaBlue142
^^ This...
I had the same exact thing happen to my 02 Dakota. I would turn the key, hear the fuel pump, accessories would come on, no engine. I would try 6-7-8 times and it would finally turn over.
It got progressively worse through the course of a couple months... finally replaced the starter and haven't had the issue since!!
Usually the easiest solution is the correct one!!
