Help-Electric Fan Controller Wiring
Old Apr 6, 2012 | 11:21 AM
jondakotaguy's Avatar
jondakotaguy
Default Help-Electric Fan Controller Wiring
Hey guys; need a little input here I'm planning on doing the electric fan upgrade to an HHR fan and getting rid of my fac Clutch; I'm reading up on the product I will use;
http://www.flex-a-lite.com/auto/31147-99936.pdf
and I need a little help in determining where a good power source controlled by the on/off of the vehicle might be if anyone knew so i wouldn't spend forever and a day hunting for a reliable one that is capable of handling 20amps.
Old Apr 6, 2012 | 05:47 PM
5hundo's Avatar
5hundo
Honestly, when I've done electric fan installs in the past, I usually just hook mine directly to the battery. That way, the fan will keep blowing, even if the engine is off. Believe it, or not, engines actually heat up initially after the ignition is turned off, due to the coolant not being circulated anymore. If the fan can get rid of the heat in the radiator after I shut down, it could be a little bit easier on my engine...
In reality, the fan is not going to draw enough of a load to kill your battery after you've shut the ignition off anyway, so I really wouldn't worry about finding an ignition lead and wiring into it. The only drawback is the occasional idiot who tells you "Your car is still running!!" but just ignore them...
Old Apr 6, 2012 | 09:19 PM
jondakotaguy
Yeah I know about the heat build up... it's great to keep the engine from getting hotter but my truck never gets over 200 when its turned off.. if it's really hot it will climb to about 210 but thats not that bad..
My thing is i run a high end audio system and really dont need the fan pulling that extra juice.. alt has a hard enough time as it is.. thanks for the information; I'm still searching the truck for a suitable source.. in case anyone knows of one.
Old Apr 7, 2012 | 06:41 AM
keg97's Avatar
keg97
I ran a wire through the firewall and hooked it to the ignition switch.
Old Apr 8, 2012 | 10:21 PM
jondakotaguy
Alright thanks for the feedback... I'll be checking out my options
