Towing wires
Old Apr 22, 2012 | 10:08 PM
Kyguylal's Avatar
Kyguylal
Default Towing wires
I don't have the towing package on my 2000 Dakota sport. What will I need to do for wiring to tow a small uhaul utility trailer? I bought a hitch but I looked under the bed and found a wire coiled up with two ends on it that comes out of the wire that leads to the back lights. Will it be as simple as soldering on a plug to those wires?
I should be fine towing a trailer that weighs about 800 pounds all loaded? It's the 3.9 5 speed
Old Apr 23, 2012 | 01:44 AM
BlueQC's Avatar
BlueQC
There are kits that just "T" into the tail lights and gives you all the 4 circuits,
White = Ground
Green = Right turn
Yellow = Left turn
Brown = Tail lights
Quick and easy! All for $20
Old Apr 23, 2012 | 07:54 AM
Kyguylal's Avatar
Kyguylal
Ok thanks!
http://autoplicity.com/products/7955...keModelFitment
Would that be all I need? Just hooks into the tail light plugs?
Old Apr 23, 2012 | 02:58 PM
BlueQC's Avatar
BlueQC
That is all you need.
unscrew tail light lense ,connect and feed wires down to hitch area.
Old Jul 27, 2012 | 04:55 PM
giomi59's Avatar
giomi59
curious as to how this would work for both sides as it appears it only plugs into one side?
please educate me.
Old Jul 27, 2012 | 06:28 PM
magnethead's Avatar
magnethead
I used the Hoppy kit from Autozone. $20. T-taps the chassis/body interconnects on either side of your spare tire.
Old Jul 27, 2012 | 09:47 PM
Kyguylal's Avatar
Kyguylal
I'm not sure the brand that I ended up buying. Cost me 15 bucks. Two plugs just t into the brake light plugs. Worked great for the uhaul
