Power Steering Leak
Old Apr 30, 2012 | 12:57 PM
tomgraz's Avatar
tomgraz
Originally Posted by 98DAKAZ
So the pressure sensor was not the leak or you just decided to change out pump anyway?
Dak, I looked at everything carefully while Dad turned the steering wheel from side to side. The pressure sensor is high up on the high pressure line and it was dry. It would seem that a seal on the pump itself was leaking down and off the bottom of the mounting bracket. Everything below that point has fluid splashed on it. I also checked the point where the high pressure line connected to the rack. It didn't look like it was the leak either.
