2004 Dakota Turn Signal Relay location?
Old May 7, 2012 | 09:35 PM
kfulford's Avatar
kfulford
Default 2004 Dakota Turn Signal Relay location?
Can anyone tell me where the turn signal relay is on a 2004 Dakota? It's not in the fuse panel. Thanks.
Old May 8, 2012 | 01:56 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd Generation Dakota Sub-forum. In there you can download the owners manual that will have it listed.
Old May 8, 2012 | 06:25 PM
kfulford's Avatar
kfulford
Default Thanks
OK, thanks a lot.
Old May 8, 2012 | 09:29 PM
01SilverCC's Avatar
01SilverCC
The Service Manual for my 2001 says the turn signal flasher is located under the dash panel on the driver's side, "outboard of the dash opening". I think that might mean to the left side of the steering column. Maybe your 2004 is the same. There is no relay listed for the turn signals, only the flasher and fuse.
Jimmy
