transmission cooler??
Old May 9, 2012 | 06:23 PM
oledb4's Avatar
oledb4
Default transmission cooler??
I'm considering installing a transmission cooler on my '04 3.7 v6 Dakota. I tow a boat on the weekends and also have heard it could have some mpg effects, as well as prolong my tranny life. Any experience/thoughts?? thx
Old May 9, 2012 | 07:16 PM
UWAdventurer's Avatar
UWAdventurer
One came on my truck because of the tow package on it. It sure can't hurt anything, cooler tranny temps are a good thing for the fluid.
Old May 9, 2012 | 09:16 PM
moe7404's Avatar
moe7404
you need a external fluid filter, auto zone, 2210. goes in the line going to the rear tube, just find a good place to put it, when you cut the tube you need to bulge the line a little so the hose stays. its best to use high pressure hose. allso the factory may have put a check valve in the line, you need to remove it. i add rear end grease to the trans, or take some out, then add back. some think iam crazy, BUT IT works if the cooler lines go into the cooler in the vertical radiator on the right side of the truck, the bottom line has the check valve, if it has one. if you have a vertical cooler on the left side, not using the radiator, the line going to the rear, aka return, may have a check valve in the return line. behind the radiator.
