lift kit quality
Old May 11, 2012 | 01:25 PM
driev's Avatar
driev
Default lift kit quality
so i have found several lift kits thanks to the FAQ, for my 04 dak (v6 4x4 quad cab) i'm looking for something small, 2-3 in, my mane question (i have used the FAQ, and search on here and cant fined anything on this...) is, is there any kits to stay away from? anyone have horror stories about any ebay kits or??? looking for something around $300+ or so...
Thanks
Pick.
Old May 13, 2012 | 03:37 PM
Xxaler's Avatar
Xxaler
Not really anything to avoid in the 2-3" range.
You're either looking at lift blocks in the rear + crank the torsion keys in the front, or a 3" body lift. Blocks can be had for less than $100, and body lift under $300. Just make sure the kit includes a steering shaft extension. Depending on year, if you have the manual transfer case make sure it comes with an extension, and if it has manual transmission you will need one too.
Old May 13, 2012 | 03:54 PM
Brian_'s Avatar
Brian_
crank the front end t bars to level it out then go body lift. with suspention you get barely anything out of the front until you hit the front bumpstops and have insane angels on the cv's.
Old May 14, 2012 | 10:15 AM
jondakotaguy's Avatar
jondakotaguy
Yeah.. That's what happens when they put a Foo-Foo Front diff. on a truck.. they used these on Liberties and such foo-foo jeeps like that.. Unlike the Wrangler that actually has a real drive shaft... that's not tucked into the frame like a wiener on a fat dude.
Old May 15, 2012 | 10:24 PM
ahsnowlover's Avatar
ahsnowlover
I was able to get 2 inches out of my torsion bars and still have clearance between the a-arm and lower bump stops. As for the back I just got 2 inch blocks and had new u-bolts made for it.
Old May 17, 2012 | 01:11 PM
Brian_'s Avatar
Brian_
how much of a rake do you have snow lover?
Old May 18, 2012 | 09:27 PM
ahsnowlover
I think I have a slight rake but not bad, when I get a chance this weekend I'll find a flat spot to park and take a pic of it
