Front suspension clunk HELP!
Old May 16, 2012 | 01:19 PM
alt-fuel's Avatar
alt-fuel
Default Front suspension clunk HELP!
I have a 2001 QC 3.9 4x2. Have a clunk on the passenger side when backing out of the garage. Replaced upper,lower bushings and ball joints both sides and both wheelhubs. All parts moog. I live in Mesa AZ. Not much left to replace. Does anybody have an idea what else?
Old May 16, 2012 | 06:12 PM
McNasy's Avatar
McNasy
not up on 2wd knowledge, but sway bar bushings?
Old May 16, 2012 | 08:48 PM
mindcrash's Avatar
mindcrash
rotors, tie rods?
Old May 16, 2012 | 09:41 PM
ramitt360's Avatar
ramitt360
Mine did the same thing on the passenger side. I replaced everything but the sway bar. Turns out the link was snapped..
Old May 16, 2012 | 09:54 PM
01SilverCC's Avatar
01SilverCC
Stabilizer bar (sway bar) end links. You will get the clunking when going slow over speed breakers too. Napa Chassis with their lifetime warranty or any other good name brand parts will work best. I replaced my own end links around 70,000 miles and again when I did my ball joints at about 120,000 miles. The second time one of the boots was ripped, Napa warranty exchanged the whole part for me. I had to buy a replacement for the other side though, because I stripped out the threads on it (not a warranty defect) when I removed it while replacing my ball joints. Stay away from the cheap Chinese junk parts on ebay. Good parts will cost maybe $30.00 or $35.00 each, and it's not hard a hard job at all to replace them.
Jimmy
Old May 17, 2012 | 10:59 AM
alt-fuel's Avatar
alt-fuel
Thanks for all the feed back. After I posted the problem I jacked the right side of the truck to check wheel bearings and found it too sloppy to the point the anti-rattle for the caliper was making noise on the hub. Well thats another $133 changed in 2010. Too bad there isn't an adjustment. Thought that might be the problem but wrong again. The sway bar ends look and feel good. The noise I do hear is a dull clunk.
Old May 17, 2012 | 03:04 PM
ramitt360's Avatar
ramitt360
Hmmm.. things that make you go hmm. Does it happen when you hit a bump? turn a certain way at a certain speed? Can you feel the clunk or just hear it? Is your truck lowered or stock?
Old May 17, 2012 | 05:39 PM
alt-fuel's Avatar
alt-fuel
Stock height and I can feel it. It happens when cold first in the morning backing out garage. In my garage I have curb put tires against get home from work. The next morning put in reverse and back away then clunk. Can't seem to make it happen again only in the morning when leaving for work. Feel once and a while pulling out of parking space.
Old May 18, 2012 | 08:52 PM
ramitt360's Avatar
ramitt360
odd, Well I am at a loss I hate to say. Nor do I have my old dakota to look at for possibilities. The fact that it only happens in the morning is odd. Check all the bushings I guess.
Old May 18, 2012 | 08:58 PM
Xxaler's Avatar
Xxaler
Hate to say it, but have you got underneath and checked out your exhaust?
Even with all the hangers in place, sometimes you can still have quite a bit of movement, enough to contact other parts.
