Need to Replace Wheel Bearing
Old May 30, 2012 | 05:20 PM
sxrsil3nt's Avatar
sxrsil3nt
Default Need to Replace Wheel Bearing
Hey guys,
I've had a pretty bad noise coming from the driver side front wheel hub for a while now and I have to replace it. I'm going to replace the entire hub - if anyone has ever done this before - can I get away without having to remove the axle? If I can make it as simple as possible I will, but I just want to see if I have to pull the axle out too.
Thanks!
Old May 30, 2012 | 05:58 PM
Brian_'s Avatar
Brian_
when i was at the tire shop (family friend) i had to replace the passenger one. you will need to take the caliper and such off, dont let it hang! there will be a nut in middle of hub take that off then 3 bolts behind the assembly. keep in mind this was a 30min job with fancy shop tools.
Old May 30, 2012 | 06:30 PM
dolittle's Avatar
dolittle
You will not need to remove the axle.
Do a search here or on goggle there are some wright ups on how to do it.
The hardiest part of the job for me was geting the hub off after I had all the bolts out a big hammer was what I needed.
Old May 30, 2012 | 08:39 PM
sxrsil3nt's Avatar
sxrsil3nt
Thanks - I have tools, I just wanted to know if I was gonna need an axle puller incase my BFH wasn't good enough - now I know I don't need one at all! I'll let you know how it turns out.
Cheers!
Old May 31, 2012 | 02:03 AM
mmguy18's Avatar
mmguy18
The axle nut is 36mm. As I have said before bought mine off ebay at Detriotaxle like them.
Sell one like this
1 FRONT (LEFT or RIGHT) "Dakota" WHEEL HUB BEARING "4WD 4X4 w/REAR WHEEL ABS"
Seller: Member id detroitaxle ( Feedback Score Of 46158)
99.9% Positive feedback
Save this seller | See other items from this seller | Visit store: Axle of Dearborn
Item condition:New
Compatibility: See compatible vehicles
Quantity:More than 10 available / 20 sold
Price:US $42.05Buy It NowBuy It Now
