v6 shifting problems
Old Jun 12, 2012 | 10:39 PM
Cameron Hill's Avatar
Cameron Hill
Default v6 shifting problems
Hey I have a 99 v6 2wd and it wont rev over 3500 rpm I can stop on the gas and thats as far **** gets then shifts I replaced the trans speed censor and had the same problem however if I unplug the speed censor it shifts normally for about a week then it wont shift at all and slips badly.
Old Jun 13, 2012 | 12:04 AM
Cameron Hill
Also, there were no codes, when I hooked it up at the auto parts store. It's got 104k On it and the Motor runs perfectly fine, ( could be a motor issue??? Unlikely) The tires might have something to do with it? They're 235 75 r15's The truck is rated for 215 75 r15's. I don't know if that would affect it or not.Now heres another thing when I unplug the TSC Everything in the truck works fine the Speedo The Tac, Everything Now i'm not to good with Transmissions but, if you unplug that thing should the Speedo stop responding aswell. Now I know theres an Input and and Out put TSC I replaced the output (Near the rear of the Transmission) And I also know theres a Censor on the Rear Axle. Should I replace all Three? I've messed around with the TV cable, but that doesn't change a thing when I have the TSC I'm not sure if It affects it when it's unplugged I haven't messed with it yet. I might try that. And see if it will shift out of 1st In a week or two.
Old Jun 13, 2012 | 07:37 AM
moparnick's Avatar
moparnick
The sensor on the rear diff is what measures the speed. How high does it rev with the transmission in neutral?
Old Jun 13, 2012 | 01:21 PM
Cameron Hill
It will rev to fuel cut out, when in N or Park. Also, it will shift normally if I manully shift it.
