03 Dakota window switch problem
My passenger side window switch only works when it wants to, which is usually never. If I have a passenger with me, and they want the window down I usually have to roll it down with the driver side controlled. Could it be because the window lock switch is completely missing. Or does the problem lie else where?
Is the lock switch button missing or just not there at all? I had a similar problem. Besides the drivers window, sometimes you could open the other windows and sometimes not. I ended up jumpering out the lock switch and they've all worked ever since. I never use that lock switch anyway. Do a search, there's a write-up. That's how I found it. A couple of wire taps and a 6" length of wire and your done.
