front disc brakes..and cal
Old Aug 26, 2005 | 12:31 AM
jcc's Avatar
jcc
Default front disc brakes..and cal
ok I just replaced my front brake pads & rotors..
2000 dodge dakota 2wd...
the caliper bolts don't go in as far as they where before I started..
about 1/8 an inch or less .. they are in the hole & the caliper is tight..
I replaced the pads before (with my dad's help) but I don't remember the pins being a problem...
could the pins be diff for the top than the bottom... I might have put them in wrong.. but both sides are the same after...what are the ods of that (with my luck 100%..
ps the brakes work fine on the down the block test but I don't wanta take my chances on the highway..
thankz for any help
I did a seach but found nothing specific...
