transmission pan material?
Looking to put a trans temp gauge in my truck, need to know what material the pan is to get the right material bung. Gonna get the pan from here seeing as I cant see $210 for an aluminum deep pan.
I'm assuming it's stamped steel and can have a steel bung welded to it?
Haven't decided where to put the sender at, orientation wise. Need to check out clearances.
Main problem is that the digital gauge only has an 8 foot lead, and if I put the gauge where the ash tray is, I have no idea how to get the wires down to the transmission without cutting and splicing them with extensions.
The drilling and welding will be done off the vehicle. Just a matter of checking fit and making sure I don't hit anything.Plus the bung will hold the sensor out of the pan a bit, so only the 1/2" probe should stick in.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your chrysler trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com.au/magna-fine.html
2. for other sizes wix 58964 5/16 tube size reff:http://www.wixfilters.com/filterlook...sionfilter.asp
NEW SUBJECT: .distributor moisture fix. Some chrysler distributor cap that has an air vent, needs to have the vent plugged. Best to use JB-weld. But there might be some brands that run air through as part of the system, dont seal them
are they stamped steel or ???
Local racer will be TIGing the bung on. Going to have the pan switched when I get the trans fluid changed here in not too long. Getting a real bad RPM spike on the 2-3 shift at WOT, breaks loose to shift at 3000, jumps to 3700 or so, then down to 2500 when things hook back up.
Trending Topics
it's supposed to be a factory replacement for a jeep cherokee's 42RE. I havent taken a magnet to the stocker to see what kind of material it is. I figured for cost, it would be stamped steel.
its hitting 2 nd gear to hard. call A & Reds 3737 W. 29th S.
Wichita, KS 67217
316-942-5300
800-835-1007
they can answer ANY Q you have. and have ANY parts you need. i have known this out fit since late 60s
Wichita, KS 67217
316-942-5300
800-835-1007
