Its Time To Lift
Old Aug 24, 2012 | 09:06 PM
deanomarino11's Avatar
deanomarino11
Default Its Time To Lift
i want to lift my truck up. its been called little on more than one occasion.. do i get a body lift or suspension lift kit? whats the real difference in functionality and the pros and cons of each?
Old Aug 24, 2012 | 09:17 PM
BCdakotaboy's Avatar
BCdakotaboy
Body lift is cheaper than a suspension lift. Depends on what you want to do with your truck. If It's just to lift it higher, body lift. If your wheeling it a suspension lift is better. I've done both in mine so its about 8" higher than stock.
Old Aug 24, 2012 | 10:10 PM
Tom A's Avatar
Tom A
Section Moderator
If you're just after "the look", a body lift is easier and a lot less expensive. But a body lift alone is limited to three inches.
Old Aug 25, 2012 | 08:27 AM
mmguy18's Avatar
mmguy18
My understanding is if you have a rack and pinion steering you are limited to a body lift. Like BCdakotaboy said depends what you want to do with it.I did a 3 inch body lift and 2 inch blocks in the back and crank the torsion bars in the front.
Old Aug 26, 2012 | 05:01 PM
deanomarino11
is there a kit that has everything ill need?
Old Aug 26, 2012 | 05:20 PM
Tom A's Avatar
Tom A
Section Moderator
Performance Accessories 60043
Old Aug 27, 2012 | 10:03 PM
jpayne80's Avatar
jpayne80
While installing the PA body lift was a pita I love the look. Best mod to date!
