AC Drain
Old Sep 9, 2012 | 07:09 PM
98DAKAZ's Avatar
98DAKAZ
If you have no room to get a tube up in the area put small globs of the selant on your finger and smear it around the drain tube till it builds up enough
Messy but will work
Old Sep 9, 2012 | 07:12 PM
markk96's Avatar
markk96
Yes that will not be a problem. I have to remove the wheel and the plastic cover in side the fender area. It is right behind a small heat shield.
There is a tube that the Dodge Caravan uses as a fix. But there is no room on my Dakota because of the shield.
Old Sep 9, 2012 | 07:15 PM
98DAKAZ's Avatar
98DAKAZ
As a way to suck out the plug find some tubing that fits the drain and a long enough tube and suck it out.
With a vacuum
Old Sep 9, 2012 | 08:28 PM
markk96's Avatar
markk96
There's not much room to do much.
Old Sep 12, 2012 | 02:41 AM
sl2racer's Avatar
sl2racer
good info
Old Sep 13, 2012 | 11:18 PM
sl2racer's Avatar
sl2racer
did this today. it was easy took about 10 minutes and hardest part was getting the old plastic rivets that holds the splash shield off. cut the heat shield so i could reinstall after i put the 90 on.
Old Sep 13, 2012 | 11:43 PM
dodgeramguy85's Avatar
dodgeramguy85
I didnt feel like driving 10 min to get new ones so I used a bunch of self tapping screws I had laying around made for easy removal next time lol
Old Sep 14, 2012 | 04:34 PM
sl2racer's Avatar
sl2racer
i ended up using the finned push in ones. that way i can remove and reuse them again.
