Rad Removel
Old Aug 26, 2012 | 04:47 PM
Wetodd's Avatar
Wetodd
Default Rad Removel
Hey Guys my rad is leaking where it is crimped on to the plastic at the end.
I have a 2001 4.7 4X4 QC how long does it take to get the rad out and does it lift out once you pull the plastic Res and Fan shroud out.
I would like to do it my self to save cash.
Thanks
Old Aug 26, 2012 | 05:20 PM
98DAKAZ's Avatar
98DAKAZ
Default DIY or shop cost
Look on the first page of the forum you can download a service manual with all the info you need.
But usually it’s not that much in labor at a shop I would get a few estimates then check what just the rad may cost and possibly a hose or two plus antifreeze and clamps so on then come to a conclusion on DIY or shop cost verses time to do it.
Old Aug 26, 2012 | 10:16 PM
mmguy18's Avatar
mmguy18
Just did mine.Got the antifreeze out than removed upper shround than top and bottom hose, Removed 2 transmission lines. There are two bolts up top and it should pull up and out. If you haven't done so recently should change thermostat too.
Old Aug 26, 2012 | 10:22 PM
mmguy18's Avatar
mmguy18
Sorry lower shround should come off to and you need to unplug Electric fan. I left fan on and swap to new one when it was out the truck.
