Lift kits
Old Sep 3, 2012 | 03:01 PM
mmguy18's Avatar
mmguy18
I think it up to your own personal taste. But I believe at least 31's or better yet 33's
Old Sep 3, 2012 | 03:11 PM
Tom A's Avatar
Tom A
Section Moderator
I think 33s will rub. You're probably better off with 31s. Just my personal opinion.
Old Sep 3, 2012 | 04:30 PM
jpayne80's Avatar
jpayne80
I have a body lift, lifted the front an inch with torsion bars, and fit 32s without rubbing.
Old Sep 3, 2012 | 07:02 PM
BCdakotaboy's Avatar
BCdakotaboy
Without any kind of lift 31's will be the max size you can go, altho they may rub on hard turns. Body lifts are fairly cheap, easy to install and will allow larger tire sizes.
Old Sep 27, 2012 | 05:06 PM
devlindak84's Avatar
devlindak84
ive got 31's on and no rubbing at all, good year rangler territory. putting a 2" bl kit on tomorro and shopping 33's right now.
Old Sep 27, 2012 | 11:51 PM
Trent479's Avatar
Trent479
you would be in the clear to put on 31's and still get some tuck on em when you wanna flex. check out the good years wrangler dura tracs one tire rack! i got a great deal
Old Sep 28, 2012 | 01:40 PM
devlindak84
ya i was looking t the dura tracs, it came down to those and the cooper stt, and since ive had the stt before i chose that tire. im gonna have to careully measure after this 2" lift and mke sure they are gonna work. im hoping. would look pretty good if they do. orst case i could buy some spacers i suppose.
Old Sep 28, 2012 | 03:42 PM
Trent479's Avatar
Trent479
they should fit! ive got a 2.5 inch lift and my dura tracs fit with plenty of room. I did take my wheel well plastic out but before that it still didnt rub at full crank!
Old Sep 28, 2012 | 08:33 PM
Tom A's Avatar
Tom A
Section Moderator
I've used Duratracs and I currently have STTs on my truck. I would say you can't go wrong with either one.
Old Sep 29, 2012 | 12:00 AM
devlindak84
Uh oh, got the blocks in and the steering is blocked by the Aftermarket headers.
Might have To modify the header or find stock manifolds.
Or
Does anyone have this 3" lift with headers on? If so what kind?
