98 Dak 2WD front bushing replacement?
Old Sep 3, 2012 | 05:53 PM
98DAKAZ's Avatar
98DAKAZ
Question 98 Dak 2WD front bushing replacement?
I need my front A-arm bushings replaced soon I have the top bushings but need to get the bottom ones and it’s kind of confusing as to how many there is just two to each side or 4 to each side the bottom is what I’m asking about rockauto is confusing as to the ones I need and how many.
It also looks like if only two per side on the bottom both are different is this correct? Like lower front and lower rear?
I think this what I need correct?
Old Sep 3, 2012 | 09:05 PM
mmguy18's Avatar
mmguy18
There 2 per side need 4 total
Old Sep 5, 2012 | 10:28 AM
98DAKAZ's Avatar
98DAKAZ
Lightbulb
Well I ordered them I think they are the correct ones.
I have another question has anyone use a DIY rent a shop place at all Im looking at this place in Arizona as a place to do my own work I have no space to do this at home at this time.
the rent a shops... we have a few out here in AZ
http://www.diyauto.biz/
or http://www.ufixitautomotive.com/
Old Sep 5, 2012 | 10:40 AM
98DAKAZ's Avatar
98DAKAZ
The other reason to use the DIY shop is lots of room to work and I think they will do side stuff for you like pressing out and installing the bushing for me doing that is the hardest part of the job and the most frustrating part.
Plus save me a ton of time not needing to do the extraction and install of the new bushings
Then they can do an alignment on the spot after all the new parts are on also.
Old Sep 7, 2012 | 01:23 PM
98DAKAZ's Avatar
98DAKAZ
Thumbs up ready to go
I also need to replace the top Ball joint on the passenger side at the same time I skipped this last year but its time now.
