Removing engine decal (near front headlights) on '99 Dakota
Hey all,
I just removed most of my decals from my Dakota, but the engine emblems (the ones right next to the side of each headlight) are still there.
Is there a way to remove these without damaging my paint?
It seems like they are glued pretty tight on there.
Thanks,
Brady
Thanks,
Brady
I used a hair dryer and some fishing line to cut the adhesive off mine, then elbow grease to get the residue off. My '99 had an alignment pin and a hole in the fender behind it - I understand some don't - perhaps different year models. Just check it out before you do it if you are thinking of leaving it unbadged. I put a Cummins badge in its place after my swap so it worked well for me.
Patrick
Patrick
