On Board Air
Old Oct 2, 2012 | 10:21 PM
Wes Garrett's Avatar
Wes Garrett
Default On Board Air
Ok, i have been reading posts everywhere of Jeep owners building On Board Air systems. I have yet to see anyone do it with a Dodge. So guess what, I'm doing it, and will be posting pics and how I did it, as it progresses.
Old Oct 2, 2012 | 10:43 PM
Wes Garrett
First things first, the vehicle is a 2000 Dodge Dakota with a 3.9L v6. in lieu of repairing the ac system (leaking). I found it more sensible to convert it to OBA. The pump is the stock sanden sd7h15 (u 4774).
i started with draining the AC system (actually there was noting in the system.. it leaked), then i removed the stock manifold block from the pump. once that was completed, i cut the alum lines to what i needed from them, basically the manifold and approx. 5-8 inches of line. tomorrow i will place the manifold back on, and confirm the suction and output side.
i will post pics of the progress tomorrow.
Old Oct 3, 2012 | 03:46 PM
dodgeramguy85's Avatar
dodgeramguy85
Dont forget to add a inline oiler or oil it before each use. I had one on my cherokee. Great for on the trail.
Old Oct 3, 2012 | 04:39 PM
Wes Garrett
oh i planned on it, just going to start with an inline tool oiler for testing.
i havent had time to get to the truck today, i do belive i have some time in a bit that i can get out there and get pics.
Old Oct 3, 2012 | 04:47 PM
Wes Garrett
i am unsure of one thing... whether i can get away with using compression fittings on the alum. pipe, or should i just cut it flush and tap it using 1/4" NPT..
any input would be appreciated
Old Oct 3, 2012 | 04:55 PM
dodgeramguy85
You prob can. My pump actually had screw in fittings so it just needed some threaded pipe and some brass fittings.
Old Oct 3, 2012 | 05:01 PM
Wes Garrett
i wish mine was that easy.. haha.. im thinking tap.. although crapsman air compressors use compression on alum. pipe. i guess at this point its a matter of time and money, $9 for the tap, or like 14 for the comp fittings.. cant find em under 6 anywhere local.. it also looks like that it doesnt matter wich way i put the manifold back on the comp, so if i did tap it i can just flip the manifold
Old Oct 3, 2012 | 05:31 PM
dodgeramguy85
Prob better off to go with compression fittings
Old Oct 4, 2012 | 09:49 AM
Wes Garrett
how long did the unit last on your jeep?
Old Oct 4, 2012 | 11:30 AM
dodgeramguy85
A long time. As long as they are oiled and not run all the time you will see some good life out of them. Just put yours on a switch or unhook the connector when you are done.
