Help! 1997 Dode Dakota
Old Oct 24, 2012 | 12:05 PM
jake10245's Avatar
jake10245
Default Help! 1997 Dode Dakota
I have a 1997 Dodge Dakota sport 3.9 5spd. Currently sitting at 181,xxx. About 3 months ago i was on my way to work and im on the highway doing 60-65 mph and my truck decides it wants to start sputtering and i had to pump the gas all the way to work so it wouldnt die. I got to work and i didnt smell anything or see anything wrong i wasnt even throwing any codes. so later on that day after i got off i started my truck up just fine drove fine until i got back on the highway and it wanted to start sputtering again and this time it backfired and sounded like a shotgun. It lost power and i still had it in 5th gear but it slowed down on its own and even downshifting and pumping the gas it didnt help. so i came to a complete stop and it died and wouldnt crank back up. after about 15 minutes just letting it sit i tried to turn it over and it started back up so i got it home as quickly as possible and parked it. Then throughout the next few weeks i drove it a little bit hoping it would throw a code and finally it did. I took it up to autozone and it threw a code for the ingnition coil and an O2 sensor. So i just thought it needed a tuneup. I got all new plugs, wires, distributor cap and rotor, and an ignition coil. Just replaced all of it about 3 days ago and it ran smoother, quieter and no sputtering or backfiring. I thought it was fixed. I took it on the highway and it did just fine and about 5 minutes of being on the highway it started sputtering again but it stayed on all they way until i got home. Parked it again. Got in it this morning and it barely started up and i drove it down the street to take it to the shop and it sputtered and died. Had to wait a few minutes for it to start back up and i brought it home. Im kind of confused on what my options are and what would be the best idea. Can i get some help? Thank you
Old Oct 25, 2012 | 12:37 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Oct 25, 2012 | 08:35 PM
Tom A's Avatar
Tom A
Section Moderator
Check your fuel pressure.
Old Oct 27, 2012 | 09:03 PM
jake10245's Avatar
jake10245
Fuel pressure looks stable. Im gonna go ahead and replace the fuel pump anyways but thanks for that advice!!
