3.9 Got Nuff' Ponies for 33's?
Old Nov 6, 2012 | 09:52 PM
BCdakotaboy's Avatar
BCdakotaboy
I have 33s and a 3.9 , have a standard tranny tho. Yea I've noticed the difference with a larger tire, want to re-gear just haven't found a set yet. Giving the 3.9 some up grades has helped but gearing is the way to go.
Old Nov 6, 2012 | 11:53 PM
magnethead's Avatar
magnethead
If you do mostly highway driving, you should be fine. Just don't get anythign with too aggressive of a tread pattern- your OD will thank you.
Or just remember to hit the OD off button every time you get in the truck. 33's are a enough overgear that you may not need OD.
Old Nov 7, 2012 | 09:49 AM
3point9's Avatar
3point9
New Member
Till I get some money for a regear i'll hold off. I will never remember to turn OD off in the mean time, most of my driving is city.
What are the chances of finding a dak with the 8.25 rearend and with 4.10 gears at a wrecker hahaha.
Thanks for now guys.
Old Nov 7, 2012 | 11:12 AM
dodgeramguy85's Avatar
dodgeramguy85
Very very rare cause they never came with 4.10's. 3.92's would be the best you would find. I have 4.10's and hate them coarse they wont swap cause my axle makes yours look like a tooth pick lol
Old Nov 7, 2012 | 01:25 PM
magnethead's Avatar
magnethead
FWIW I went to 4.10's and the shop charged me $1000 for one end. But he's a damn good guy so I was willing to drive 30 miles each way and pay more for a quality job. I have 29.5's right now (the regear was for racing and to unload the motor, not tire matching) and honestly I would say go for it. The trans going into OD in the city probably will rarely happen with that big of a tire- I'd be more worried about turning 1200 rpm on the highay and the trans going in and out of OD. Keep in mind that the regear will likely NOT correct your speedo. I just used a dry erase marker and re-marked the plastic window over the speedo using the GPS on my phone as a calibrator (the 29.5 tire still has an offset error).
Old Nov 7, 2012 | 10:17 PM
Tom A's Avatar
Tom A
Section Moderator
After I do my SAS, I'd be happy to sell you my front axle with 4.10 gears, but the shipping would probably kill you. I'm going to have to keep my rear for a while, though, since it works fine and I don't really have the funds to upgrade it.
