truck turns off while driving, lights flicker
Old Nov 22, 2012 | 03:24 PM
unwedsailor's Avatar
unwedsailor
Default truck turns off while driving, lights flicker
First thing I noticed was my dash lights and headlights would flicker a little here and there, then more frequently. Then my truck started turning off while driving at random. Today it would cut out and then turn back on while.driving. the radio stays on and doesn't cut out when the engine does. Had battery tested, its good. My check engine light was on and after the engine cut out, it was off, so it seems to me like what ever is happening, its cutting power from the battery and clearing the codes? Anyways, I've checked the terminals, they are clean. I replaced the positive connector. Any idea what could cause this? I did replace the radio in Feb or march. But didn't have any problems till November.
Old Nov 22, 2012 | 09:24 PM
Crazy4x4RT's Avatar
Crazy4x4RT
What year is your truck so I can move this to the correct place?
Old Nov 23, 2012 | 12:49 PM
unwedsailor
1998 sport
Old Nov 23, 2012 | 08:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Dec 3, 2012 | 05:13 PM
gnelson49's Avatar
gnelson49
Do your lights dim? Manual or Automatic? In gear or out? Does your voltage gauge and oil pressure drop when this happens before it dies? What about the idle, is it steady?
