fan/steering issue.
Old Nov 26, 2012 | 08:57 AM
krypto1o1's Avatar
krypto1o1
Default fan/steering issue.
ok so first the fan issue is that my blower works on the floor and on the defrost... but not the front face blowers. i think they were working this summer...
second is my steering. i am about to change my tirods as they are worn and the tire when on my hoist will move. so today i am going to put some cheep ones on for the winter until i can afford moog ones... but the sttering goes off to the right so when i drive im ALWAYS holding it off to the left a bit., any suggestiongs? i am going to try stop leak for the rack and pinion cause i cant afford a new rack yet and i intened on changing it after winter passes.. but should i keep my winter tires off the front because of this or what? (all seaons on front[31''x10.5/15 atm and winters on the back 265s)
Old Nov 26, 2012 | 09:37 AM
98DAKAZ's Avatar
98DAKAZ
First what year is your Dak
Second if replacing your tierod ends you will need an alignment if you can’t afford it and they are only a little lose the tierod ends that is I would wait till you can get everything in the front fixed at one time then get an alignment done.
Your air vents if the vacuum ones has a vacuum leak or your one way/check valve is not working look here for answers on that LINK
Old Nov 26, 2012 | 09:44 AM
krypto1o1's Avatar
krypto1o1
its a 2000 dakota v6 3.9 5 speed manual. and is it bad if i do a rope alingment at the shop?
Old Nov 26, 2012 | 10:06 AM
98DAKAZ's Avatar
98DAKAZ
If you feel you can do it the rope alignment give it a try I have never done it
That link should help with the vent problem
What is also needed new Ball joints or bushings? or what?
I ask because I have found out replacing your top ball joints can be very easy and cost you $20 each
Old Nov 26, 2012 | 11:03 PM
krypto1o1's Avatar
krypto1o1
yea well i can get the joints from partsource at garage cost because my mechanic i help out listed me as an apprentice to them soo i get cheap costs at a few places. and i have done a rope alignment already and figured i would do it again, or ill get a cpu one done since i have 31' tires and canadian tire will be like 80 and ill do it with my dads credit card.
Old Nov 26, 2012 | 11:05 PM
krypto1o1's Avatar
krypto1o1
and everything else seems to be alright. i was checking cause i had it on the hoist.. its all tight atm.. just the tirods. soo i wanted them changed. (my mechanic showed me the rope alignment he has been a mechanic for 30 years and does a **** ton of taxis and used to work at bigger garages but this is the smallest one so far.)
