3.9L motor help
ok guys, most of you know that im doing a complete truck rebuild,
well im to the point where i can put the motor and trans back in. i do not have the cab wired, as its going to the scrap heap when i get the new cab.
i want to be able to run the motor after i rebuild it, and i am wondering EXACTLY what circuts i need to connect to make that happen. i kno i need the PCM and all the engine and trans harnesses, but what ones on the BODY and Accessory harness circuts do i need.. im trying to do this with out reconnecting the ENTIRE truck... if i absolutely have to, i will. but i would ike to be able to run it with minimal circuts..
