Heater blows cold - tried almost everything
Old Dec 9, 2012 | 06:53 PM
98DAKAZ's Avatar
98DAKAZ
For the best info on the 2.5L engine check out all the Jeep forums the Jeep used the same exact engine for many years in a number of there autos.
The offical name is the AMC 2.5L 150 engine
Old Dec 9, 2012 | 06:55 PM
98DAKAZ's Avatar
98DAKAZ
More on the 2.5L http://en.wikipedia.org/wiki/AMC_straight-4_engine
And http://www.allpar.com/mopar/amc-25.html
Old Dec 9, 2012 | 10:13 PM
98DAKAZ's Avatar
98DAKAZ
Wink
Found a cool pic of the AMC 2.5L in a Jeep
Old Dec 9, 2012 | 11:56 PM
98DAKAZ's Avatar
98DAKAZ
A 2.5L getting pumped up
Old Dec 10, 2012 | 06:09 PM
rickself's Avatar
rickself
HEAT!!
We have heat! And you should of seen the gunky crap that came out of the hose.
Thanks, 98DAKAZ!
Old Dec 10, 2012 | 07:36 PM
98DAKAZ's Avatar
98DAKAZ
Ok glad things are good
Old Dec 12, 2012 | 01:20 AM
Jadam701's Avatar
Jadam701
I have a 2000 with the 3.9, and the same problem. It has been going on for about a month, and with the winter in Maine, it is no fun. I have replaced the thermostat, and flushed the heater core, and nothing came out except for clean antifreeze. The blower is blowing, and it does blow warmish air, but not the hot air it was just a few weeks ago. I also think the truck seems to be running about 10 degrees cooler than it was before, and have only been able to get it to heat up over 205-210 once. Should I be running a warmer thermostat for winter?
Old Dec 12, 2012 | 01:24 AM
magnethead's Avatar
magnethead
I have a 180 stat in mine with the mk8 fan mod set to 190 and it only comes on if i've been sitting, even when it was 29 outside with light snow on the ground. Heater was plenty warm.
The stock thermostat is 195 and I think the stock 16" fan is supposed to kick on at 210 and off at 205.
Old Dec 12, 2012 | 01:29 AM
Jadam701's Avatar
Jadam701
I would really like to get rid of that stock fan. The truck will warm up, just not the cab. The one time I got it to heat up over 205-210, I was parked on a steep hill for 10 minutes or so. I hate how the gauge is numbered, but I am guessing that mine is running around 180, maybe 185 for the most part, but of course, I could be wrong. I would love a set of digital gauges in there
Old Dec 12, 2012 | 01:30 AM
magnethead's Avatar
magnethead
mine isn't numbered at all. The fan kicking on/off is only way I know the temp.
I'm getting an Ultragage ASAP. Look it up, not bad for $60.
