installed used transmission
Old Dec 21, 2012 | 12:12 PM
RYCOMA79's Avatar
RYCOMA79
po700 is a general transmission fault code if you pulled codes up on the odometer that is all you'll get you need to use a scanner that can pull trans. codes. that will tell you exactly where to start looking.
