2000 dakota remote starter help!!!!
Old Dec 26, 2012 | 03:28 PM
jrschleicher's Avatar
jrschleicher
Default 2000 dakota remote starter help!!!!
hello, im trying to install a prestige aps57c remote start on my truck. i feel i have all the necessary wires connected but i need some help. if someone could please list all the wires that are needed to be hooked up and also, the lock/unlock work, but when i try to remote start the truck, the brain of the starter just clicks 7 times and nothing happens please, any and all information will be greatly appreciated. Thanks in advance!
Old Dec 26, 2012 | 03:47 PM
01SilverCC's Avatar
01SilverCC
I am not familiar with a Prestige remote start but try this link for your truck's wiring info:
http://www.the12volt.com/installbay/...etail/702.html
Does Audiovox or Prestige have a technical help phone # you can call for assistance? If so I would start there first.
Jimmy
Old Dec 26, 2012 | 06:09 PM
tommyis3's Avatar
tommyis3
Sounds Like a programming Tach issue to me:
2. Programming Tach Rate:NOTE:All applications require that tach be programmed.
The unit will not operate unless tach is programmed. If an attempt is made to start the vehicle via the remote start without first programming tach, the unit will flash the parking lights 7 times indicating tach has not been learned and stored.
If the tach rate is not properly programmed to the specific vehicle, the unit may not realize that the vehicle is running in certain instances and could re-engage the starter motor.
The Remote Car Starter will learn the tach rate of most vehicles single ignition coils, multiple coil packs, and or single injector. To learn tach;
1. Turn the ignition key to the ON position.
2. Press and release the program switch 3 times.
3. Immediately turn the ignition key OFF.
4. Hold the program switch ON, then start the vehicle using the ignition key.
5. When the unit senses the tach signal, the parking lights will begin to flash.
6. Release the program switch.
The parking lights will turn on for 3 seconds to indicate that the tach signal is storedand the unit is now out of the program mode.3. Diagnostics:1. Be sure that programmable feature number #9 is set to the "Diagnostics On" mode.2. Press and hold the program switch on, then turn the ignition key to the "ON" position.3. The lights will flash and the number of flashes will indicate the reason for shutdown on the last remote start attempt.The indications are as follows.1 Flash 5, 10, 15, or 20, minute run timer expired.2 Flashes Low or No tach signal received.3 Flashes Positive input shut down.4 Flashes Control switch was moved to "Off" position.5 Flashes RF Shutdown command received.6 Flashes High RPM signal over speed shut down.7 Flashes Tach has NOT learned.8 Flashes Negative input shut down Multi Coil Pack Adapter: (Optional)The multi coil pack adapter, (P/N 136B1400), is designed for use with vehicles that do not respond to single coil tach programming. Although the tach resolution of this circuit is designed to interface direct with most vehicles, there maybe an occasion where the following circuit may be required.To use the adapter, the Green/Black wires must connect to the negative side of the ignition coil(s).1. For vehicles utilizing independent coils per cylinder, connect the three Green/Black leads to alternate coils.
Old Dec 26, 2012 | 11:32 PM
jrschleicher
the only button is on the antenna. is that the program switch that i press?
