Engine noise
Old Dec 30, 2012 | 04:38 AM
johnhoj's Avatar
johnhoj
Default Engine noise
So ever since I got back from Florida, Ive had this noise when I start up cold. It sounds like its coming from the driver side exhaust manifold and goes away or gets a little quieter when it warms up. I haven't noticed any power loss or anything different at all, but I'd really like to know what it is. Any help is appreciated.
Old Dec 30, 2012 | 04:43 AM
mmguy18's Avatar
mmguy18
Could have a bad exhaust manifold gasket. Should be able to look on that side while it is running and hear a leak or not.
Old Dec 30, 2012 | 04:49 AM
johnhoj's Avatar
johnhoj
ive tried that and cant tell. think it hurt just to change it? ive looked it up and the driver side manifold doesn't look that hard to change at all.
Old Dec 30, 2012 | 09:20 PM
Tom A's Avatar
Tom A
Section Moderator
You can check for exhaust leaks by holding a piece of vacuum hose to your ear and using the other end like a stethoscope to listen all around your exhaust manifold. When you find the spot that's leaking, you'll hear it very clearly.
Or you can just change it. It's a relatively easy job (unless the bolts break when you try to remove them).
Old Dec 31, 2012 | 04:19 PM
mmguy18's Avatar
mmguy18
On the drivers side the exhaust manifold could be a little more work. The steering shaft is right there. But still a fairly easy job. But like Tom A said be prepared to replace a bolt/stud or 2.
Old Dec 31, 2012 | 06:00 PM
johnhoj's Avatar
johnhoj
ha, so i was going to do it yesterday but i jacked it up and was looking at the heat shield bolts. the upper rear was already sheered off. ever heard of a bolt sheering off by itself or should i be making a call the the dealership where i bought it.
Old Dec 31, 2012 | 06:07 PM
98DAKAZ's Avatar
98DAKAZ
Yes they can just snap off by themselves it happens more than you think usually they were tightened too much to start with or with age they can snap off
Old Dec 31, 2012 | 07:32 PM
johnhoj's Avatar
johnhoj
Well thats good i guess. any thoughts on easy out or should i have it done at a shop.
Old Dec 31, 2012 | 07:57 PM
mmguy18's Avatar
mmguy18
Good old rust. My heat shields have done the same thing but shields themselves are shot. Price them at $45 for the pair. So I have decided not to replace them. Looking at some sort of wrap and maybe just paint them.
