Removing the 7 & 8 coil packs
Old Jan 6, 2013 | 06:19 PM
Robbadodge's Avatar
Robbadodge
Default Removing the 7 & 8 coil packs
Big issue trying to remove the coil packs on 7 and 8. get them moving that little bit when twisting, but they just won't budge to get up!
I've even tried using pry wrenches and a crow bar! Wishing I had a slide hammer to try and rig on it.
I obviously don't know if the problem is on the spark plug or the rubber o-ring.
Help please! It's getting cold outside and I want (need) to get this done tonight.
Thanks!
Old Jan 6, 2013 | 06:31 PM
98DAKAZ's Avatar
98DAKAZ
Any silicon spray at hand or WD 40 will do in a pinch.
Talk about that grease sounds like it wasnt used last time they were removed that rubber can glue to those sparkplugs
Old Jan 6, 2013 | 06:43 PM
Robbadodge's Avatar
Robbadodge
Sounds like it!!!
My wife, the love that she is, went and got the grease and anti-seize while I removed the other 6.
try the silicone spray first I guess, got both.
Thanks!
Old Jan 6, 2013 | 06:51 PM
98DAKAZ's Avatar
98DAKAZ
Happened to me a few times the boot refused to come off a plug then pop it came free. Even the silicon wires can get glued to the plugs over time
