lights killed battery FAST
Old Jan 14, 2013 | 03:09 AM
  #21
Wes Garrett's Avatar
Wes Garrett
i have no clue, ill probably get the isolator from AW Direct.. seems easy enough to install.
Old Jan 14, 2013 | 03:19 AM
  #22
magnethead's Avatar
magnethead
That's your best bet.
My biggest issue is the fan. Not everything runs at once, but the fan kills alot.
Old Jan 14, 2013 | 08:06 AM
  #23
magnethead's Avatar
magnethead
29 degrees out
Battery was 11.89 sitting, 11.24 with low beams and HID's on, key off. Was slow to crank again. 14.37 running with lows and HID's on, no fan.
Old Jan 14, 2013 | 02:02 PM
  #24
Wes Garrett
Originally Posted by magnethead
29 degrees out
what needs to be determined is the amperage between the alt and the batt, if the alt is putting out 14v thats right in the threshold. im still dead set on the bad cell in the battery
Old Jan 14, 2013 | 09:04 PM
  #25
magnethead's Avatar
magnethead
Each cell- 2.1V x 6 cells = 12.6-12.8 nominal 'off' voltage
2.1V x 5 cells = 10.5 V
The actual voltage splits the difference, so a bas cell is possible.
Old Jan 14, 2013 | 09:16 PM
  #26
98DAKAZ's Avatar
98DAKAZ
It could be an intermittent problem or never show up on a test I had a battery like that one time you tested it over and over and always came out as ok I decided to change it and no more problem
Old Jan 15, 2013 | 10:57 PM
  #27
magnethead's Avatar
magnethead
You nailed it. 9.9 volts, click click click. Got a start boost by university PD, went to the AZ near campus, free replacement. It's a grou 34 BTW, 800x1000 CCA, 105 minute reserve.
Old Jan 15, 2013 | 11:31 PM
  #28
Wes Garrett
wait who nailed it? haha
Old Jan 16, 2013 | 12:10 AM
  #29
magnethead's Avatar
magnethead
oh, I checked voltage with the new battery. With fan on is 13.7 at the cabin power outlet, fan off is 14.1. So not too big of a drop. But I'm sure the alternator is at 60+% load.
Old Jan 16, 2013 | 12:36 AM
  #30
magnethead's Avatar
magnethead
everybody I second guessed? :P
