Power mirror plug problem
Old Jan 17, 2013 | 06:46 PM
alaskajeff's Avatar
alaskajeff
Default Power mirror plug problem
The PO installed new power mirrors. While they bolted up and fit properly, they were from a different year Dakota that used a different plug. Take a look: The black plug I am holding is the harness in the door, the white plug above it is from the mirror. The door plug has 3 wires and the mirror plug has 5 wires. Can i cut the plugs off and splice? Which wires go to where? HELP!!
Old Jan 17, 2013 | 06:48 PM
alaskajeff's Avatar
alaskajeff
The door plug has a pink, blue, and yellow wire. While the mirror plug has 2 black wires, a white, yellow, and light blue wire. Don't you just LOVE hack work!
Old Jan 17, 2013 | 08:56 PM
Tom A's Avatar
Tom A
Section Moderator
The extra two wires are probably for a heater. No idea what color those are, though.
Old Jan 17, 2013 | 09:25 PM
alaskajeff's Avatar
alaskajeff
Good point Tom, they are heated mirrors! So IF I can figure out what wires go where I could get them to work. I'm sure the heat part has a positive and ground wire, so thats why there are 2 black wires. I SHOULD be able to splice the 2 grounds together and then splice the heater positive with the power positive?? In theory it should work, right?
Old Jan 17, 2013 | 11:13 PM
Tom A's Avatar
Tom A
Section Moderator
I think you'd be better off wiring a separate switch for the heat. If you download one of the FSMs from the links in the FAQ, they probably have a wiring diagram that would tell you which wires are which.
Old Jan 17, 2013 | 11:42 PM
magnethead's Avatar
magnethead
yes, you have heater mirrors on a non-heater truck. IMO, I never use my heated mirrors. You living in the land of ice may want them.
Page 879 of FSM
This is from 2001 so your will differ.
Mirror switch: Orange/Yellow
Driver L/R: Dark Blue/White
Driver U/D: Yellow
Pass L/R: Dark Blue
Pass U/D: Yellow/Black
Heater: Yellow/Dark Blue and Yellow/Black.
