Winter gas, No Ethanol...make sense?
Guess I just want to hear it....
Even Ethanol Free gas has a winter mix, right? After cleaning the intake (vacuuming in Sea Foam), replacing the plugs and getting the truck in "perfect working order", I had a long highway trip where I could test the mileage. When it calculated to 16.7, I felt a little cheated; then I remembered the winter mix and should expect a lower average.
The best I ever got in the past was a tick over 19 mpg with or without Ethanol (don't think it ever got above 20).
If Ethanol Free doesn't have a winter mix, then something really sucks here.
What do you think?
What do you think?
I didn't post a good title. I know normal winter blend has Ethanol.
What I meant to ask is more along the lines if I purchase No Ethanol, will there still be a winter blend associated with it. By the sounds of it, there is and the 16.7 mpg is probably pretty good right now.
4.7 3.55 quad 4x4
Thanks y'all!
4.7 3.55 quad 4x4
Thanks y'all!
Yes there is still a "winter blend" associated. You might get better gas mileage with no ethanol, test it and see!
