Spider gears are they OK?
Old Feb 21, 2013 | 04:10 AM
alaskajeff's Avatar
alaskajeff
Default Spider gears are they OK?
Take a look and tell me what you think? Should I be worried? The ring and pinion gears were fine. It's an 8.25 with 145K miles on it.
Old Feb 21, 2013 | 09:19 AM
98DAKAZ's Avatar
98DAKAZ
No those dont look good at all how much gunk was on the magnet or was it clean if clean someone knew they were on the fix it list.
If thats a 8.25 it looks different that my 8.25
spiders.jpg?t=1361456923
Old Feb 21, 2013 | 10:09 AM
magnethead's Avatar
magnethead
The good part: spiders are easy to replace.
The bad part: You still have to pull the carrier from the axle (the cross pin wont clear the ring).
Old Feb 21, 2013 | 10:17 AM
98DAKAZ's Avatar
98DAKAZ
Unhappy
With those chipped up spiders I would worry about the bearings steel chips could be in the bearings or the bearings could be bad now.
A complete R/R of the rear would be advisable
