check engine light / stall
Old Mar 24, 2013 | 07:59 AM
Dakotaquad's Avatar
Dakotaquad
ok i really hate the dam crankshaft position sensor on my truck the dam thing is so rusted in that i cant get it out. ive tried everything i own. last thing i did last night was sprayed it down it wd-40 and let it sit over night to see if it gets threw all the crap.
Old Mar 25, 2013 | 06:44 PM
Dakotaquad's Avatar
Dakotaquad
well i will say this to anyone that decides they need to change out there crankshaft sensor. Be ready to break it and dremil out the rust on inside edge of the port in order to remove the rest and be sure to drill 2 holes in the sensor so u can grab it with a pair of needle nose pilers.
Old Mar 26, 2013 | 10:54 PM
TheePlaymaker's Avatar
TheePlaymaker
Did it help you out though with the new one? Sucks to hear it was in there so bad, I don't remember mine being as painful sounding as that though.
Old Mar 27, 2013 | 07:59 AM
Dakotaquad's Avatar
Dakotaquad
yes other then the crazy removal it did the trick and i have no more code. thank you
