Adjusting shift points
Old Mar 26, 2013 | 04:34 PM
Dodgeboy77's Avatar
Dodgeboy77
Default Adjusting shift points
anyone here ever adjusted shift points with a superchips 3815? when i floor it the 1st to 2nd shift has a hesitation before shifting and i wondered if i should adjust the shift point up or down to fix this. thanks
Old Mar 26, 2013 | 05:19 PM
magnethead's Avatar
magnethead
what engine do you have? Shift points are only adjustable on the *.7 motors with the 5/45RFE trans. 4*RE transmissions cannot be adjusted as they shift hydraulically.
Old Mar 26, 2013 | 06:01 PM
Dodgeboy77's Avatar
Dodgeboy77
4.7, 545 rfe trans
Old Mar 29, 2013 | 10:20 AM
jondakotaguy's Avatar
jondakotaguy
44RE you can adjust slightly by adjusting the Trottle Valve cable.. I increased mine by like 6mph difference when i had it almost adjusted all the way it could safely go.. just random wild shifts at WOT.. i backed off a little still gives me nice powerful shift transfers gear to gear but no weird shifting at WOT>
Old Mar 29, 2013 | 12:09 PM
Dodgeboy77's Avatar
Dodgeboy77
i thought there was no cable for the 545rfe
Old Mar 29, 2013 | 01:16 PM
magnethead's Avatar
magnethead
Jon is thinking the 4*RE for the magnum motors. The 545 trans for the *.7 powertech motors, I'm not sure of, but I don't think there is since they're fully electronic.
