Auxilary Fuel tank?
Old Apr 15, 2013 | 02:42 AM
Jeff Leal's Avatar
Jeff Leal
Default Auxilary Fuel tank?
Hi guys,
I'm just wrapping up a HEMI swap on my 02 4x4 Dak, and with the exhaust now routed on the outside of the frame rails there is a lot of space freed up under the bed so I was thinking of adding an auxiliary fuel tank just because. I was hoping to put another 22 gal tank if possible and use the same pump/sender as factory tanks have that way I can "T" all the lines (minus the fill tubes) and then with a relay bank I could use a single switch to go between the main and aux tanks at a moments notice. The relay bank would switch the power between the pumps and the level sensors so that the fuel level of the active tank is displayed on the cluster.
Soo.... Anyone have any ideas for a tank? I've been looking all over and I can't seem to find anything for Daks, but I see tons of stuff for the full size trucks. I was almost wondering if I could just put another factory tank on the passenger side?
Old Apr 15, 2013 | 03:26 AM
magnethead's Avatar
magnethead
grab your tape measure....I bet that'd be the easiest route to go.
