Dakota lift and 33s
Old Apr 27, 2013 | 09:43 PM
jacobclif_9's Avatar
jacobclif_9
Default Dakota lift and 33s
I've been looking around and haven't found the answer I want. Will ONLY a 2" rear block and 3" torsion bar lift fit 33x11.50 tires and 0 offset wheels? I have a 4x4 QC
Really need help with this haven't found much about this
Old Apr 28, 2013 | 11:59 AM
01blackdak's Avatar
01blackdak
I can tell you that you wont get a true 3" out of the stock torsion keys and with re-indexed keys.
Just put on a block and key lift last weekend. I got about 2 1/2" of lift in the front. Anymore than that and you wont have any adjustment to have your tires properly aligned.
I have 265/75-16's (31.5x10.5) With the lift they come within an inch or so of rubbing the bumper when you turn. So with 33's I'd imagine they would rub.
If you want to run 33's go with a body lift it's quick and gets the result you want without have to trim anything.
Old Apr 29, 2013 | 11:50 AM
DakCC4x4's Avatar
DakCC4x4
The problem in answering your question is the wheel offset. That is not the factory backspacing so not sure. Stock back spacing then yes u can fit with minor trimming up front
