Dakota sounds like a diesel?
Old May 13, 2013 | 03:52 PM
kyleweaver55's Avatar
kyleweaver55
Default Dakota sounds like a diesel?
I have a 2000 3.9l Dodge Dakota and one day when I started it it sounded not good and almost like a diesel sound to it. All the power was there so I checked plugs, fluids, ect and everything seems alright but once it warms up a few miles down the road it sounds normal untill it sits and gets cold again? I have not done anything prior to it so I couldn't blame it on anything. Any ideas? It's not showing any codes either.
Old May 13, 2013 | 09:53 PM
jpayne80's Avatar
jpayne80
Check out the exhaust manifold gasket and bolts. Very common on the 4.7, don't know if it is common on the 3.9, though.
Old May 13, 2013 | 10:14 PM
Klokworx's Avatar
Klokworx
i have the same problem on my 2.5. i second paynes opinion
Old May 13, 2013 | 10:31 PM
Ryan Passini's Avatar
Ryan Passini
I think I have a similar issue. possibly more than one. Mine sounds like piston slap, but I think there might be an exhaust leak too. Is there a gasket material I can use instead of taking the manifold off? With 200k on it, Im worried about snapping bolts....
Old May 14, 2013 | 01:16 AM
Klokworx's Avatar
Klokworx
gasket maker... but bolts are better than rubber if they snap on their own
