tire width
Old May 15, 2013 | 08:48 AM
tomrosenberger2004's Avatar
tomrosenberger2004
Default tire width
I bought my Dakota with the 31X10.5-15 tires instead of the narrower 235/75-15 that the factory provides. Given the power steering issues with the Dakota's, would it be wise to replace the wider tires with narrower 235/75-15 tires?
I was thinking that if the truck had less rubber on the road, the power steering system would not be strained as much.
I have steel racks on the front and over the cab and bed to haul building materials, so the trucks heavier than normal. Additionally, the roads where I work in Costa Rica are full of pot holes. Gracias for your suggestions. TR
Old May 15, 2013 | 11:49 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
This is the Durango section. You would need to ask this in the Dakota section.
FF
Old May 15, 2013 | 12:13 PM
sxrsil3nt's Avatar
sxrsil3nt
You can also get 31" from the factory as an option so I wouldn't worry about it.
Most members here without a lift will run 31" tires or the metric equivalent.
Old May 16, 2013 | 08:31 AM
tomrosenberger2004
This is the DodgeForum.com > Dodge Trucks > Dodge Dakota > 2nd Gen Dakota section, not the Durango section
Old May 16, 2013 | 09:41 AM
1969CoronetR/T
vaffanculo
It was moved after my post to the correct section from the Durango section.
FF
