Rough idle repaired
Old Jun 9, 2013 | 11:20 PM
Propwash's Avatar
Propwash
Default Rough idle repaired
I was having a rough, kind of rumbling, idle on my 5.2. I replaced the plugs with the correct type (previous owner had installed iridiums of the wrong heat range and type) and a new cap and rotor. Engine got much better for a while. Then the rough idle was back. So I did a search and the posts indicated a dirty throttle body and IAC valve could be the culprit. Well that was the case with a 92 Mustang 5.0 I had, so I thought I better have a look on the 5.2. Sure enough there was enough crud around the plates to cause the IAC valve to go nearly full open I guess. I also had a slight surging at cruise power around 30 mph.
I bought a Felpro TB gasket ( $2.21 my wholesale cost!) and pulled and the IAC valve. Fifteen minutes later all was well.
Thanks to this site that's about the cheapest automotive repair I've done since the 1970's!
Old Jun 10, 2013 | 09:45 AM
DAK99OTA's Avatar
DAK99OTA
I just did the same thing on my 4.7 this weekend, and now it runs like it has 30k instead of 140k.
