Transmission rebuildt now truck wont start
OK i believe i know what the issue is. But i was wanting some others input, maybe you have done the same thing.
I didn't watch the Crank Sensor close enough, so i did smash it wired between the bell housing and engine. But i have got the crank sensor out and also got the connector, minus the foot of wire between the two. So i'm gonna splice it (I do it for a living so it'll work).
So my question is would that keep the engine from starting? More specific ------ would that keep the fuel pump from supplying fuel to the engine? because i don't hear the pump running when i turn the key to the on position, i usually do.
Thanks in advance!!
Thanks in advance!!
It will definitely keep the engine from starting. Not sure about the fuel pump thing.
