where is the water leak
Old Sep 28, 2005 | 04:05 AM
abandoned's Avatar
abandoned
Default where is the water leak
ok, she made it all the way from Seattle to San Diego, but the other day I found antifreeze dripping from the driverside. There is no hose over there and could not see anyplace for it to come from. Going to pull off the shroud tomorrow and see if I can get a better look. I'm thinking the radiator might have cracked since I cant find a hose or connection in that area.
any suggestions out there?
[IMG]local://upfiles/21525/F14032C256924B92BE750B68D8BEC54D.jpg[/IMG]
Old Sep 28, 2005 | 06:27 AM
horatio102's Avatar
horatio102
Default RE: where is the water leak
Could be a radiator problem, could be a freeze plug on the block, where's it coming from?
Old Sep 28, 2005 | 11:39 AM
abandoned's Avatar
abandoned
not a freeze plug. Water is driping from frame brace right under the radiator on the driverside. Drips from there regardless of angle of the truck. that is what is leading me towards a cracked radiator.
Old Sep 30, 2005 | 01:16 AM
abandoned's Avatar
abandoned
well it was the radiator..... why are ours so darn expensive.....
ok the truck was pretty much free so I guess the starter, battery, radio and now a radiator are ok expenses...
Old Sep 30, 2005 | 01:20 AM
Daksport1pa's Avatar
Daksport1pa
How much is a radiator for our trucks?
Old Sep 30, 2005 | 04:59 PM
DanDB64's Avatar
DanDB64
If you want a new radiator and need better cooling abilities...
Click Me For Another Option
'Nuff said
