Transmission Compatibility
Old Jul 27, 2013 | 03:35 PM
Stillraining's Avatar
Stillraining
Default Transmission Compatibility
I have searched for this info but cant find it.
I have a 2000 Dakota quad Cab 4x4 with the 5.9
I found this tranny out of a 92 1500 2 wheel drive and im wondering if it is compatible with my truck...can I just change the tail housing with my transfer case. Its a 46RH A518
I did the vin# search on my truck but its inconclusive to me what I still have for a tranny here is the build codes.
Trans Order CodeDGB, DDC
Trans Type4, 5 (4.0 min/5.0max)
IM 2200 miles away from the truck right now so I cant crawl under it for any numbers or any other identification
Thanks
File Type: jpg
Old Jul 27, 2013 | 04:30 PM
Old_School's Avatar
Old_School
Thanks
No it wont work... you need a RE (electronically controlled) transmission and that is a RH (hydraulically controlled).. IIRC after '97 is what year your looking for a donor.
Old Jul 27, 2013 | 05:58 PM
Stillraining
Bummer OK thanks...that one was only 300.00
